test ip phone ring from gateway
It seems that i have forgotten the undocumented command to test connectivity and ring funtionality to an ip phone. On the gateway I configure a test voip dial-peer with the session tatget set to the ip address of the 7960 phone. Then you can issue this command and test aux vlan and connectivity status from the gateway. Trouble is i cant remember the command. Can anyone help? Thx.
Re: test ip phone ring from gateway
Hi Brad,
I think you might be talking about the csim start command from GW.
csim start 4xxx
Allan
Hey Allen,
That's it...Many thanks...
119
