Testing VIC2-2FX S and VIC2-2FXO cards
I want to setup two 2611XM routers with a
NM-HD-2VE ( 3 DSP), VIC2-2FXS, VIC2-2FXO cards.
Can I connect the FXS to the FXO ?
Do I need to have telephones with RJ11 Straight through cables connected to the ports of the VIC's.
Could you point me to somewhere where this scenario is addressed. ( Voice certification test lab diagrams...)
Thank you,
Tom
Re: Testing VIC2-2FX S and VIC2-2FXO cards
Hi Tom,
FXS will always connect to FXO. Consider your provider to be FXS, and analog phones to be FXO ports.
You should be able to use a normal telephone cable to connect between the FXO and FXS.
I don't know of any documents that specifically say anything for back to back FXS/FXO, because they are documented separately normally.
hth,
nick
Dear Experts
This is going to be my first implimentation of the Voice network and is turning out to be a nightmare.i have reffered all the configuration mannuals , books and videos but still not able to make calls across the MPLS network.Need help urgently to solve the issue.
Here is the senario
PSTN>>>FXO(Cisco2905)>>>>>MPLS Cloud<<<<<<<(Cisco2905)FXS>>>>>>>>Phone
here is the configuration i have done
voice-port 0/1/0
voice-port 0/1/1
connection plar 2201
voice-port 0/1/2
voice-port 0/1/3
mgcp profile default
dial-peer voice 998 voip
destination-pattern 22..
session target ipv4:192.168.220.1
dtmf-relay cisco-rtp
dial-peer voice 100 pots
destination-pattern 9............
port 0/1/1
on
voice-port 0/0/0
cptone ID
voice-port 0/0/1
cptone ID
dial-peer voice 220 pots
destination-pattern 2201
port 0/0/0
forward-digits all
dial-peer voice 221 pots
destination-pattern 2202
port 0/0/1
forward-digits all
dial-peer voice 110 voip
destination-pattern 9T
session target ipv4:192.168.0.1
Early response is much appriciated
REGARDS
SANDEEP
621
