TFTP Port Numbers from Call Mgr
We have noticed that upon boot up, an IP Telephone Set will send tftp requests to the Call Mgr tftp server using udp/69. However, the TFTP server responds back with udp and port numbers greater than 59000 (at least in the time period that I have been looking at this). I wonder if there is a defined range of port numbers this TFTP server (ver 4.1) will use when downloading configs to the IP Telephone Sets?
Re: TFTP Port Numbers from Call Mgr
The response can be on any random high port (1024 - 65534). Please see the following link for confirmation.
http://support.microsoft.com/kb/832017
Hope this helps. If so, please rate the post.
Brandon
Bronze
Hi smith,
I found the port range at SRND for CCM 4.1
It starts of UDP 69, then use range between UDP 49152 and 65535.
Here is the link:
http://www.cisco.com/application/pdf/en/us/guest/products/ps5820/c2001/ccmigration_09186a00804474f2.pdf
Please go to page. 484
Please rate the post if it helps.
Ken
153
