The best way to blcok long distance call?
Which one is the best way to blocking long distance?
1. Create a 9.@ RP and add a RF with LONG-DISTANCE-DIRECT-DIAL EXISTS.
2. Create a 9.1xxxxxxxxxx RP and select "Block this pattern".
3. Create a 9.[2-9]xxxxxxxxxx RP and select "Route this pattern".
Bronze
Re: The best way to blcok long distance call?
What I would recommend would be to block long distance calling with the use of Partitions and Calling Search Space. For example, build a few Partitions: InternalPT, LocalPT, LongDistPT, IntlPT. Then build some CSS's: InternalCSS, LocalCSS, LongDistCSS, IntlCSS. Then inside each CSS put the appropriate Partition. For example: In the LocalCSS you might have InternalPT and LocalPT. In the LongDistCSS you would include InternalPT, LocalPT and LongDistPT. Now build your route patterns and assign the appropriate Partition. For example: 9.[2-9]xxxxxx = LocalPT and 9.1[2-9]xx[2-9]xxxxxx = LongDistPT. Now on each phone you want to block long distance assign a CSS of say LocalCSS. If you want no one to call long distance then just don't define the 9.1 route pattern.
All of your options work.
I would suggest choosing the method that means the most to you and your support long term.
Option 1 provides you with lots of flexibility, but could quite easily be changed by accident and no longer works.
Option 2 Is a hardened option but you then need option 3 also to make other calls
Option 3 works on it's own, is pretty straight forward to understand and doesn't rely on anything else being configured.
So for me it would be option 3, however that's based on not knowing anything else about the config.
Paul
79
