Community Member
Transcoding problem
Hi, I have a CCM 3.0(9), a catalyst 6500 with E1 Blade and a 36660 with FXS interfaces.
On the port 1 of the WS-X6608 E1 is a PSTN.
If I configure one of the other ports as MTP, when i call an FXS connected telephone, let start a transcoding session between the IP Phone and the 3660.
Why this happen if all the IP Phones, gateways is on the same Region?
Nicola Morelli - CCNP
Re: Transcoding problem
On the configuration page for the 3660 H.323 gateway in CCMAdmin, did you check the box that says "MTP Required"?
Community Member
Ok!
All it's working fine!
Tanks.
101
