Transfer CUE voicemail to another system - Unity 4.0
roseeng69
Is there any way to transfer a CUE voicemail to a user on a different system - Unity 4.0 if on-net dialing is enabled? Is there any configuration that can be used to redirect it to the other system? If not, is there a way to extract the file from the router?
Rose
Rob Huffman
Hi Rose,
You could configure IMAP access on CUE and you would then have the ability to save the Voicemail as a .wav file. Or you could network the two systems together via VPIM;
IMAP;
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel3_2/administrator/voicemail/12advVM.html
Configuration Example: Cisco Unity Express Networking
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_configuration_example09186a00804dfe88.shtml#introduction
Hope this helps!
Rob
Hi Rob,
Thanks so much for the information! I'm going to try the IMAP solution.
Regard,
Rose
Hi Rose,
You are most welcome my friend!
Cheers!
Rob
