agr
Transfer does not work from pstn calls
we have a problem with incoming calls from the pstn to cisco ip phones 7960 and 7940. Transfer from internal calls work fine but the transfer of a call from the pstn to an ip phone, to another ip phone does not work.
Any Ideas ??
Thanks in advance
Andi Gruber
Bronze
Re: Transfer does not work from pstn calls
check your codec configuration on the voip dial-peer. The default MOH Codec is "u-law" on the Call Manager MOH Server.
mehmet
If the Gateway is H323 then ensure that you have an "H323-gateway voip bind scraddr x.x.x.x" command on one of the interfaces(or loopback)
We had a problem similar to this where the PSTN transfered called was getting ringback on transfer and would get disconnected sometimes.
We were running 3.1.3a , TAC provided a patch to remedy the problem.
132
