transfer to cell phone call handler disconnecting with 4.0.1
I have a call handler setup named josh-cell. I have set caller-input options 4 on my subscriber account to attempt-transfer to the josh-cell call handler. I have configured the alternate transfer rule in the josh-cell call handler with a 9 and my cell phone number. When I dial 4 from my subscriber greeting, Unity calls my cell phone. When I answer my cell phone, it immediately disconnects. Any idea what would be causing this to happen? I have this same scenario working fine with 3.1.5 and 3.2. This broken scenario is with 4.0.1 and 3.3.
josh
Re: transfer to cell phone call handler disconnecting with 4.0.1
Hi Josh
We will need some more info on this. What gateway are we using to make an outside call? If it's an IOS gateway please send us the config. Is it only happening to a cell phone and not to pstn phones?
Ullie
Thanks for the response. It seems to be happening with transfers to cell phones or PSTN phones. Here is the config from the IOS gateway with a PRI. Notice that dial-peer voice 910 is the one used for outbound calls to the PSTN via the PRI from Unity/CallManager.
voice-card 1
dspfarm
voice-card 2
no dspfarm
ip subnet-zero
ip domain name tfcu.com
ip name-server 10.1.1.3
ip name-server 10.1.1.1
ip multicast-routing
isdn switch-type primary-dms100
voice call send-alert
voice rtp send-recv
voice class h323 1
h225 timeout tcp establish 3
no voice hpi capture buffer
no voice hpi capture destination
mta receive maximum-recipients 0
controller T1 1/0
framing esf
linecode b8zs
pri-group timeslots 1-24
interface FastEthernet0/0
ip address 10.10.1.40 255.255.0.0
ip pim dense-mode
ip cgmp router-only
speed 100
full-duplex
h323-gateway voip bind srcaddr 10.10.1.40
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0:23
no ip address
no logging event link-status
isdn incoming-voice voice
no cdp enable
ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.1.1
call rsvp-sync
voice-port 1/0:23
echo-cancel coverage 16
voice-port 2/0/0
description Express Teller
voice-port 2/0/1
voice-port 2/0/2
voice-port 2/0/3
voice-port 2/0/4
voice-port 2/0/5
voice-port 2/0/6
voice-port 2/0/7
description Accounting Fax ext. 248
voice-port 2/0/8
voice-port 2/0/9
voice-port 2/0/10
voice-port 2/0/11
mgcp profile default
dial-peer cor custom
dial-peer voice 910 pots
destination-pattern 9T
progress_ind setup enable 3
progress_ind progress enable 8
port 1/0:23
dial-peer voice 200 voip
preference 1
destination-pattern [2-3,7]..
voice-class h323 1
session target ipv4:10.10.1.10
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 201 voip
preference 2
voice-class h323 1
session target ipv4:10.10.1.11
codec g711ulaw
no vad
dial-peer voice 505 pots
destination-pattern 505
dial-peer voice 2019 pots
incoming called-number 661
direct-inward-dial
dial-peer voice 750 pots
preference 1
destination-pattern 750
port 2/0/0
dial-peer voice 751 pots
preference 2
port 2/0/1
dial-peer voice 2020 pots
incoming called-number 2..
direct-inward-dial
dial-peer voice 752 pots
preference 3
port 2/0/2
dial-peer voice 753 pots
preference 4
port 2/0/3
dial-peer voice 754 pots
preference 5
port 2/0/4
dial-peer voice 755 pots
preference 6
port 2/0/5
dial-peer voice 248 pots
destination-pattern 248
port 2/0/7
num-exp 661 700
If it disconnects immediately after picking up it's most of the time a codec issue. The best thing would be to take a debug voip ccapi inout debug onto this router and check why we are disconnecting that call. Please paste the traces as well into this post and we can check it.
Ullie
Ullie- My debug voice ccapi inout is too long to post. What should I be looking for as far as a codec mismatch goes? Thanks for the help on this one!
102
