Transfering calls from a POTS phone
I have 2 analogue phones plugged into FXS ports on a Cisco 2821 router. The router is connected to a converged network using Callmanager 4.1(3) and running H.323.
I can make and receive calls between the analogue phones, between them and IP phones and from them over the PSTN. However I cannot transfer calls from them either to other analogue phones or IP phones.
I also get the same problem using other types of routers.
I would be very grateful for any help received.
Gerry Seal.
Silver
Re: Transfering calls from a POTS phone
I don't think this is possible with H323, but this is available in SIP.
Configure the gateway to use SIP and add this gateway as a SIP Trunk in Callmanager.
Check this link for more details.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a00801541d3.html
Anup
Thanks for the help Anup and I will certainly give this a try.
If I use ATA186s as opposed to FXS Ports then Transfer works OK.
Many regards,
Gerry
115
