Bronze
Translate calls
Can anyone help me out understanding how to translate incominbg and outgoing calls?
This:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a0080094681.shtml
nor this:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
has helped me understand it.
I have one weird problem.
I want users to dial 0 in front of any outgoing number.
Like so 0yyyyyyyy for national numbers (Denmark) and when dialing an international number 00046zzzzzzzzz (Sweden).
When testing the voice translation rules, everything seems OK, the router drops only the first zero. But when debugging ISDN, I see that it correcly drops 1 zero when dialing national, but it drops 2 zeros when dialing international, how come?
*********debug***********
Calling Party Number i = 0x0080, 'xxxxxx43'
Plan:Unknown, Type:Unknown
Called Party Number i = 0xA0, 'yyyyyy'
Called Party Number i = 0xA0, '046zzzzzzzzz'
This is my config:
voice translation-rule 1
rule 1 /^01/ /1/ type any national
rule 2 /^02/ /2/ type any national
rule 3 /^03/ /3/ type any national
rule 4 /^04/ /4/ type any national
rule 5 /^05/ /5/ type any national
rule 6 /^06/ /6/ type any national
rule 7 /^07/ /7/ type any national
rule 8 /^08/ /8/ type any national
rule 9 /^09/ /9/ type any national
rule 10 /^000/ /00/ type any international
voice translation-rule 2
rule 1 /^/ /0/
voice translation-profile ADD-N-STRIP-ZERO
translate calling 2
voice translation-profile STRIP-N-ADD-ZERO
translate called 1
interface BRI1/0
no ip address
no logging event link-status
isdn switch-type basic-net3
isdn point-to-point-setup
isdn incoming-voice voice
voice-port 1/0/0
compand-type a-law
cptone DK
dial-peer voice 2 pots
translation-profile incoming ADD-N-STRIP-ZERO
translation-profile outgoing STRIP-N-ADD-ZERO
preference 2
destination-pattern 0T
incoming called-number xxxxxx..
direct-inward-dial
port 1/0/0
telephony-service
load 7912 CP7912080001SCCP051117A
max-ephones 12
max-dn 24
ip source-address 10.10.97.3 port 2000
service dnis overlay
service dnis dir-lookup
timeouts interdigit 2
user-locale DK
network-locale DK
time-zone 23
time-format 24
date-format dd-mm-yy
dialplan-pattern 2 xxxxxx.. extension-length 2 extension-pattern ..
keepalive 15
max-conferences 6 gain -6
dn-webedit
transfer-system full-consult
log table max-size 100
directory last-name-first
device-security-mode authenticated
create cnf-files version-stamp 7960 Apr 02 2006 09:03:55
ephone-dn 6 dual-line
number 43
ephone 2
device-security-mode none
keepalive 15
mac-address 0012.7F9B.83CA
type 7912
button 1:6
Re: Translate calls
your dial-peer 2 has 0T in it,
which will strip the 2nd 0, and rule 10 will strip the 1st
Bronze
Re: Translate calls
So this command "destination-pattern 0T" has two funktions? It both matches outgoing calls to dial-peer 2 and removes the first 0?
So if I remove the "translation-profile outgoing STRIP-N-ADD-ZERO" form the dial-peer, everything should work as intended? Or is there another way?
I'll have a go at it later today.
Bronze
Re: Translate calls
Hey hey, it works!
Thanks.
Here you go have 5 points.
253
