Translating all calls to an FXO port to a specfic DN
I am trying to setup a 1760 router as a CallManager gateway and translate all incoming calls to an FXO on the 1760 to a specfic DN in CallManager. The FXO port is connected to a regular Loop Start POTS line.
It seems like I need to be using the voice translation-rule command on the router but I am unsure how to structure the command with a wildcard to route any incoming call on that port to a specfic DN.
I was hoping someone might have an example of this that they could post, or if I am completely off track and should be using some other method to translate these incoming calls let me know.
Thanks in advance for your help
Hall of Fame Super Silver
Re: Translating all calls to an FXO port to a specfic DN
You can create voice treanslation rules, check out the link:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
Or easier way assuming you have CallManager not CCME is to create a translation pattern on CallManager and translate all incoming numbers to the desired DN.
Chris
You could also use the attendant DN field on the pots line in CCM, and or the Connnection PLAR command on the port itself in the router.
94
