translation pattern in Cisco 3845 and CCM
we have a situation where when we added translation rule in Cisco 3845, we got the below error from debug isdn q931 command
Incoming Call Not Okay (translation rule in Cisco 3845)
Call from PSTN to IP Phones
Jul 8 18:53:47.817: ISDN Se0/3/0:23 Q931: RX <- SETUP pd = 8 callref = 0x0023
Bearer Capability i = 0x9090A2
Standard = CCITT
Transer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA1838F
Preferred, Channel 15
Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info
Display i = 'LONG DISTANCE'
Signal i = 0x40 - Alerting on - pattern 0
Calling Party Number i = 0x00C3, N/A
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '800'
Jul 8 18:53:47.873: ISDN Se0/3/0:23 Q931: TX -> SETUP_ACK pd = 8 callref = 0x8023
Channel ID i = 0xA9838F
Exclusive, Channel 15
Jul 8 18:53:47.901: ISDN Se0/3/0:23 Q931: RX <- STATUS pd = 8 callref = 0x0023
Cause i = 0x82E10D - Message type not implemented
Call State i = 0x06
Jul 8 18:53:47.953: ISDN Se0/3/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x8023
Cause i = 0x80E5 - Message not compatible with call state
Jul 8 18:53:47.989: ISDN Se0/3/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x0023
Jul 8 18:53:48.041: ISDN Se0/3/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8023
Incoming Call Okay (translation pattern in CCM)
Jul 8 18:56:11.736: ISDN Se0/3/0:23 Q931: RX <- SETUP pd = 8 callref = 0x0016
Standard = CCITT
Channel ID i = 0xA18390
Preferred, Channel 16
Jul 8 18:56:11.856: ISDN Se0/3/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x8016
Channel ID i = 0xA98390
Exclusive, Channel 16
Jul 8 18:56:11.856: ISDN Se0/3/0:23 Q931: TX -> ALERTING pd = 8 callref = 0x8016
Progress Ind i = 0x8088 - In-band info or appropriate now available
Jul 8 18:56:16.668: ISDN Se0/3/0:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x0016
Cause i = 0x8290 - Normal call clearing
Jul 8 18:56:16.780: ISDN Se0/3/0:23 Q931: TX -> RELEASE pd = 8 callref = 0x8016
Jul 8 18:56:16.804: ISDN Se0/3/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x0016
Silver
Re: translation pattern in Cisco 3845 and CCM
Can you please paste the configs with the translation pattern, dial-peer and voice-port commands?
Anup
translation-rule 1
Rule 1 ^8 628
voice-port 0/3/0:23
dial-peer voice 1 pots
destination-pattern 9.T
progress_ind progress enable 8
incoming called-number .
direct-inward-dial
port 0/3/0:23
Carrier in HK only forward the last 3 digit numbers (8XX in our case) and we would like to translate the DID numbers into 628XX 5-digit internal calling numbers.
When we added "translate called 1" under voice-port 0/3/0:23, no incoming call from PSTN.
When we removed "translate called 1" under voice-port 0/3/0:23, and added translation pattern (8XX to 628XX) in CCM, it worked fine. Thank you in advance.
CCM version is 4.1(3) and runnig MGCP with 3845 T1 module.
Silver
Try adding the tranlation rule under the dial-peer.
translate called 1
Anup
Thanks.
We'll try it in the lab later as this issue is fixed now when we added the "translate called 1" command under SRST configuration. PSTN incoming calls can be received now during SRST operation.
call-manager-fallback
secondary-dialtone 9
max-conferences 8
limit-dn 7960 2
ip source-address XX.XX.XX.XX port 2000
max-ephones 20
max-dn 40
translate called 1
time-zone 43
Any idea what's the different between the below two commands?
translate called 1
voice-port 0/3/0:23
translate called 1
Thanks in advance.
383
