translation problem with country code
I am having a problem with the following configuration when dialing the international number 01181335401212. In this case, the customer dials an 8 to access an outside line. When the customer make a call (this is in SRST mode where CM is not involved), the digits being passed to the PSTN are only 13354011212. I have verified that the correct number is being dialed from the phone but the "8" that is part of the country code is being stripped. It almost seems to me like the number is being processed twice; first by the international dial peer then the long distance dial peer. Is this possible? Any ideas as to what might be going on here?
voice translation-rule 1
rule 1 // /1\1/
voice translation-rule 3
rule 1 // // plan any isdn
voice translation-rule 4
rule 1 /\(.*\)/ /9045551212/
voice translation-rule 5
rule 1 /^8\(.*\)/ /904\1/ type any national
voice translation-rule 6
rule 1 /^81\(.*\)/ /1\1/ type any national
voice translation-rule 7
rule 1 /^8011\(.*\)/ /\1/ type any international
voice translation-profile INTL-011
translate called 7
voice translation-profile LD
translate called 6
voice translation-profile Local
translate called 5
voice translation-profile inbound-Voice
translate called 1
voice translation-profile outbound-911
translate calling 4
dial-peer voice 100 pots
translation-profile incoming inbound-Voice
translation-profile outgoing INTL-011
preference 1
incoming called-number .
destination-pattern 8011T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind connect enable 1
direct-inward-dial
port 0/0:23
dial-peer voice 9 pots
translation-profile outgoing Local
preference 1
destination-pattern 8[23456789]......
progress_ind progress enable 8
direct-inward-dial
port 0/0:23
forward-digits 10
dial-peer voice 10 pots
translation-profile outgoing LD
preference 1
destination-pattern 81..........
direct-inward-dial
port 0/0:23
dial-peer voice 3000 voip
preference 2
destination-pattern 1....
session target ipv4:10.1.3.1
dtmf-relay h245-alphanumeric
no vad
118
