Trasnfer calls with TCL
I need a sample script in tcl that
1st. play a prompt
2nd. trasnfer the call an extension.
3rd. Check the connection.
Have anyone a example??
1 REPLY
Re: Trasnfer calls with TCL
Check this link out (must logged in to view it).
http://www.cisco.com/en/US/customer/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00805f2305.html
In here there is the following info that you're looking for:
In Cisco IOS Release 12.4(9)XJ and later releases, Cisco Unified CME B-ACD AA and call-queue Tcl scripts are embedded in the Cisco IOS software which are functionally the same as the scripts available in the Cisco Unified CME B-ACD tar archives. Use these embedded, or built-in, scripts as a baseline for testing and debugging customized scripts.
I have a script that we have used for auto attendant but it was paid for and therefore can not be shared. But look in the latest versions of IOS and you'll find several scripts already packaged in the IOS for you.
Hope this has helped.
Coop
115
