Trouble with CCME 4 and VIC2-2FXO; IOS 12.4(9)T
I am having trouble making outgoing call or answering incoming call.
When I try to call out from my IP 7961 phone, it fails with the message "unknown number".
For incoming call, it rings but when I pick up the call nothing happens,
Put the receiver back on hook, the phone carries on ringing. I am in UK
and just trying to set up test system with one analogue line. Any help will
be most appreciated. My config of the 2811 router is posted below. All calls ineternally works fine.
Thank you for your help.
hostname Test-CME
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1 10.10.10.10
ip dhcp excluded-address 10.139.139.1 10.139.139.10
ip dhcp pool host
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
option 150 ip 10.10.10.1
ip dhcp pool data
network 10.139.139.0 255.255.255.0
default-router 10.139.139.1
dns-server 10.139.139.5
voice-card 0
no dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
h323
sip
header-passing
registrar server expires max 3600 min 3600
interface FastEthernet0/1
no ip address
no ip mroute-cache
duplex auto
speed auto
no shut
interface FastEthernet0/1.2
description ** Data VLAN **
encapsulation dot1Q 2
ip address 10.139.139.1 255.255.255.0
interface FastEthernet0/1.3
description ** Voice VLAN **
encapsulation dot1Q 3
ip address 10.10.10.1 255.255.255.0
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:
tftp-server flash:S00104000100.sbn
tftp-server flash:TERM41.7-0-3-0S.loads
tftp-server flash:term61.default.loads
tftp-server flash:term41.default.loads
tftp-server flash:CVM41.2-0-2-26.sbn
tftp-server flash:cnu41.2-7-6-26.sbn
tftp-server flash:Jar41.2-9-2-26.sbn
tftp-server flash:term70.default.loads
tftp-server flash:term71.default.loads
tftp-server flash:cnu70.2-7-6-26.sbn
tftp-server flash:Jar70.2-9-2-26.sbn
tftp-server flash:TERM70.7-0-3-0S.loads
tftp-server flash:CVM70.2-0-2-26.sbn
control-plane
voice-port 0/3/0
connection plar opx 202
caller-id enable
dial-peer voice 1 pots
incoming called-number .
destination-pattern 9T
port 0/3/0
telephony-service
load 7914 S00104000100
load 7941 TERM41.7-0-3-0S
load 7961 TERM41.7-0-3-0S
load 7970 TERM70.7-0-3-0S
max-ephones 20
max-dn 40
ip source-address 10.10.10.1 port 2000
calling-number initiator
service phone videoCapability 1
system message MKC CME
url services http://10.10.10.1/voiceview/common/login.do
url authentication
http://10.10.10.1/voiceview/authentication/authenticate.do
time-zone 21
date-format dd-mm-yy
voicemail 600
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh music-on-hold.au
web admin system name admin secret 0 test
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
secondary-dialtone 9
create cnf-files
ephone-dn 1 dual-line
number 201
label 201
description Sarah
name Sarah
ephone-dn 2 dual-line
number 202
label 202
description Vitthal
name User2 Vitthal
ephone-dn 3 dual-line
number 203 secondary
label 203
description Neil
name User3 Neil
ephone 1
video
username "user1" password 201
mac-address 0018.18EE.947F
type 7961 addon 1 7914
button 1:1
ephone 2
video
username "user2" password 202
mac-address 0018.18BB.B973
type 7941
button 1:2
ephone 3
video
username "user3" password 203
mac-address 0018.1885.6BA2
type 7970
button 1:3
Green
Re: Trouble with CCME 4 and VIC2-2FXO; IOS 12.4(9)T
Hi Vitthal,
The config looks good to me.
Could you please paste the:
debug voice ccapi inout
debug ephone detail
Please find enclosed debug attachment for voice ccapi and ephone. First, I called from outside. Extension 202 rings but when I answered on extension 202 nothing happens. Replace the rceiever and the pone starts ringing again.Second step. I tried to call out by dialing 9 and then number but after a while phone displays unknown number.
Vitthal
On your outbound dial-peer, do you need to drop the 9? If you don't drop it, the router will forward the full dialed number (9 plus any other digits before the timeout) to the telco, and the call will fail.
Inbound, your config looks good. There might be some signalling and dtmf config you have to do, but I am not familiar with UK standards.
My understanding is that router will drop 9 before forwarding the dialled digits. However, I will drop 9 manually and see what happens. I will let you know by tomorrow.
Thanks for your help.
Vitthal
171
