Troubleshooting no busy tone
we are using CCM3.2(3)sr2 and vg200 12.2(19) with a E1 Multiflex Trunk behind a Nortel Meridian PBX.
VoIP users calling an outside number hear no busy tone if the called number is busy. The connection attempt is terminatet such a normal call disconnect (see the q931 debug).
vg200#
2w3d: ISDN Se1/0:15: TX -> SETUP pd = 8 callref = 0x0316
2w3d: Bearer Capability i = 0x8090A3
2w3d: Channel ID i = 0xA9838B
2w3d: Calling Party Number i = 0x00, 0x81, '333', Plan:Unknown, Type:Unknown
2w3d: Called Party Number i = 0x80, '00123789231', Plan:Unknown, Type:Unknown
2w3d: ISDN Se1/0:15: RX <- SETUP_ACK pd = 8 callref = 0x8316
2w3d: ISDN Se1/0:15: RX <- PROGRESS pd = 8 callref = 0x8316
2w3d: Cause i = 0x8091 - User busy
2w3d: Progress Ind i = 0x8288 - In-band info or appropriate now available
2w3d: ISDN Se1/0:15: RX <- DISCONNECT pd = 8 callref = 0x8316
2w3d: Cause i = 0x8190 - Normal call clearing
2w3d: ISDN Se1/0:15: TX -> RELEASE pd = 8 callref = 0x0316
2w3d: ISDN Se1/0:15: RX <- RELEASE_COMP pd = 8 callref = 0x8316
vg200#
VoIP users calling a Nortel phone connected to the PBX hear the busy tone if Nortel phone is busy (see the q931 debug).
vg200#
2w3d: ISDN Se1/0:15: TX -> SETUP pd = 8 callref = 0x0317
2w3d: Called Party Number i = 0x80, '371', Plan:Unknown, Type:Unknown
2w3d: ISDN Se1/0:15: RX <- SETUP_ACK pd = 8 callref = 0x8317
2w3d: ISDN Se1/0:15: RX <- DISCONNECT pd = 8 callref = 0x8317
2w3d: Cause i = 0x8191 - User busy
2w3d: ISDN Se1/0:15: TX -> RELEASE pd = 8 callref = 0x0317
2w3d: ISDN Se1/0:15: RX <- RELEASE_COMP pd = 8 callref = 0x8317
vg200#
The difference is the progress message "user busy" in the first debug. The second debug contains no Progress message, the "user busy" is part of the disconect message.
I found some tips on CCO like "voice call convert-discpi-to-prog" (http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a0080111b58.shtml) and "progress_ind progress enable" but no success.
Ideas are welcome.
Thanks a million
Silver
Re: Troubleshooting no busy tone
The PSTN is giving you a progress message that is telling the router to cut through the audio path as the busy tone is being played in band.
Try adding 'progress_ind progress enable 8' on the POTS dial peer the call is matching on and using to send the call to the PSTN.
Hi pacameron,
this is something I also tried ...
Here is the current dial-peer config
dial-peer voice 1 pots
tone ringback alert-no-PI
destination-pattern .T
progress_ind setup enable 3
progress_ind alert enable 8
port 1/0:15
159
