Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Trunks and Device Pools
I'm in a CIPT class and I'm confused about something. Why are trunks assigned to device pools? I understand (mostly) the relationship between phones and device pools, but what function do device pools perform in relation to trunks?
Thanks!
John
1 ACCEPTED SOLUTION
Re: Trunks and Device Pools
Hi John,
Remember, a device pool is a collection of specific properties to be applied to members of that device pool. It is effectively a shortcut to quickly configure devices with certain similar properties.
Stop and consider the properties in the device pool.
Device Pool Name*
Cisco CallManager Group*
Date/Time Group*
Region*
Softkey Template*
SRST Reference*
Calling Search Space for Auto-registration
Media Resource Group List
Network Hold MOH Audio Source
User Hold MOH Audio Source
User Locale
Device Pool Name* - Is descriptive for human use.
Cisco CallManager Group* - specifies which callmanager servers are involved with/utilized by the device assigned to the device pool. Phones will register with these members. And GK controlled trunks will use these servers as H323 endpoints to register with a GK. Also can be used to specify which CCM servers act as local endpoints for non-GK controlled trunks. Essentially provides redundancy for all CCM controlled devices. And in the case of trunks, it provides call processing load sharing across CCM servers.
Date/Time Group*
Obvious with phones and servers, but also can be used to sync describe the timezone assumptions for gatekeepers or other CCM clusters.
Region*
Specify the codec to be used for calls across the trunk.
Softkey Template* - not used for trunks
SRST Reference* - not used for trunks
Calling Search Space for Auto-registration - not used for trunks
Media Resource Group List - media resources available for calls across the trunk.
Network Hold MOH Audio Source - for calls across the trunk
User Hold MOH Audio Source - for calls across the trunk
User Locale - Language for text signalling across the trunk
Let me know if this helps by rating the post.
Michael
John,
Trunks use device pools to obtain a list of Callmanagers to distribute calls. See the following quote from CCM help.
"For trunks, device pools specify a list of Cisco CallManagers that the trunk uses to distribute the call load dynamically.
Note : Calls that are initiated from a phone that is registered to a Cisco CallManager that does not belong to the trunk's device pool use different Cisco CallManagers of this device pool for different outgoing calls. Selection of Cisco CallManager nodes occurs in a random order.
A call that is initiated from a phone that is registered to a Cisco CallManager that does belong to the trunk's device pool uses the same Cisco CallManager node for outgoing calls if the Cisco CallManager is up and running."
Hope this helps. If so, please rate the post.
Brandon
I had already read that text but it didn't make sense to me. Here's what I think it means. Please let me know if I have this wrong.
Just as an IP phone or gateway must register with a CallManager server, so must a trunk. Some server must be responsible for handling the trunk. A device pool has a CallManager group associated with it. This allows us to point different trunks to different CallManagers to spread out the processing load.
Is that correct?
The trunk does not register with a Callmanager like a phone. It does use the Callmanager for processing. Consider the following example:
Callmanager Group Group1
CCM1
CCM2
CCM3
Callmanager Group Group2
CCM4
CCM5
CCM6
Device Pool DP1
Callmanager Group - Group1
Device Pool DP2
Callmanager Group - Group2
Phone1
Device Pool - DP1
Trunk1
Device Pool - DP2
If Phone1 is registered to CCM1 and makes a call that goes to Trunk1, one of the Callmanger's in Trunk1's device pool (CCM4, CCM5, CCM6) will be randomly chosen to handle call processing.
If, on the other hand, Phone1 has DP2, is registered to CCM4 and makes a call that goes to Trunk1, CCM4 will always be used for call processing because Phone1 is registered to a Callmanager that belongs to the trunk's device pool.
Brandon
Hi John,
Device Pool Name*
Date/Time Group*
Region*
Softkey Template*
SRST Reference*
User Locale
Date/Time Group*
Region*
Michael
Thanks for the excellent reply! You simply wouldn't believe all the ways that our instructor sucks. He really doesn't know squat. Everyone in the class is going to demand a refund from the training company.
Thanks again!
149
