Trying to get ISDN PRI working in LAB.
I have two routers connected together via a T1 Crossover cable in my lab. I can make calls one way fine, ie I can call from ext. 2001 to ext. 7000 with no problem. However when I call from ext 7000 to 2001 I see the call go through on my traces however on the calling end I hear dialtone. On my q931 trace I notice one router is sending a Connect message instead of an alerting message. Here is the trace
00:27:41: ISDN Se1/0:23 Q931: RX <- SETUP pd = 8 callref = 0x0005
Bearer Capability i = 0x8090A2
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x0081, '7038758000'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '2001'
00:27:41: ISDN Se1/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x8005
00:27:41: ISDN Se1/0:23 Q931: TX -> CONNECT pd = 8 callref = 0x8005
00:27:41: ISDN Se1/0:23 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x0005
00:27:44: ISDN Se1/0:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x0005
Cause i = 0x8290 - Normal call clearing
00:27:44: ISDN Se1/0:23 Q931: TX -> RELEASE pd = 8 callref = 0x8005
00:27:44: ISDN Se1/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x0005
Here is some of the config from that router
no ip domain lookup
no ftp-server write-enable
isdn switch-type primary-ni
voice call send-alert
voice rtp send-recv
voice class codec 10
codec preference 1 g711ulaw
codec preference 2 g729br8
codec preference 3 g729r8
controller T1 0/0
framing esf
linecode b8zs
channel-group 0 timeslots 1-24 speed 64
controller T1 1/0
framing esf
clock source internal
linecode b8zs
pri-group timeslots 1-16,24
interface Serial1/0:23
no ip address
no logging event link-status
isdn switch-type primary-qsig
isdn incoming-voice voice
isdn send-alerting
no cdp enable
control-plane
voice-port 1/0:23
dial-peer cor custom
dial-peer voice 1 voip
destination-pattern 2...
voice-class codec 10
session target ipv4:192.168.50.20
no vad
dial-peer voice 100 pots
destination-pattern 7...
port 1/0:23
forward-digits all
Here is some of the config from the other router
no ip dhcp-client network-discovery
frame-relay switching
voice rtp send-recv
controller T1 1/0
framing esf
linecode b8zs
interface FastEthernet0/0
ip address 10.10.10.1 255.255.255.0
duplex auto
speed auto
h323-gateway voip bind srcaddr 10.10.10.1
interface Serial0/0
no ip address
encapsulation frame-relay
frame-relay intf-type dce
interface Serial0/0.1 point-to-point
ip address 192.168.200.2 255.255.255.0
frame-relay interface-dlci 100
no ip address
isdn protocol-emulate network
no isdn T309-enable
isdn T306 60000
isdn T310 10000
isdn send-alerting
no cdp enable
call rsvp-sync
voice-port 1/0:23
mgcp profile default
session target ipv4:10.10.11.100
no vad
destination-pattern 9703555
direct-inward-dial
port 1/0:23
dial-peer voice 101 pots
direct-inward-dial
port 1/0:23
forward-digits all
Any Ideas what would cause the calls not to work one way..
Ken
Re: Trying to get ISDN PRI working in LAB.
You don't have "direct-inward-dial" on the pots dial-peer for the first router.
ARRRGGGG!!!! I can't beleive I did not notice that!!
Thanks Alot
137
