trying to run axlquery with ccm6.0..plz help
i was trying to run the axlquery.asp out of the axlsqltoolkit with no success..:-((,
so i ran the java example, after some modifications, and i got all i needed.
but..
i cant run the asp, i guess i m doing something very wrong..
here is what i tried..
var authstring = text2base64(cmUserID + ":" + cmPassword);
var xmlDoc = new ActiveXObject("msxml2.DOMDocument");
xmlDoc.async = false;
var xmlhttp = new ActiveXObject("Msxml2.XMLHTTP");
var sAXLRequest;
var objNodeList,objNode,index;
sAXLRequest = '<SOAP-ENV:Envelope xmlns:SOAP-ENV=\"http://schemas.xmlsoap.org/soap/envelope/\">\n';
sAXLRequest = sAXLRequest + '<SOAP-ENV:Body>\n';
sAXLRequest = sAXLRequest + '<axlapi:executeSQLQuery sequence=\"1\" \n';
sAXLRequest = sAXLRequest + 'xmlns:axlapi=\"http://www.cisco.com/AXL/API/1.0\" \n';
sAXLRequest = sAXLRequest + 'xmlns:axl=\"http://www.cisco.com/AXL/API/1.0\" \n';
sAXLRequest = sAXLRequest + 'xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" \n';
sAXLRequest = sAXLRequest + 'xsi:schemaLocation=\"http://www.cisco.com/AXL/API/1.0 axlsoap.xsd\">\n';
sAXLRequest = sAXLRequest + '<sql>SELECT * from devicenumplanmap </sql>\n'
sAXLRequest = sAXLRequest + '</axlapi:executeSQLQuery>\n';
sAXLRequest = sAXLRequest + '</SOAP-ENV:Body>\n';
sAXLRequest = sAXLRequest + '</SOAP-ENV:Envelope>\n';
xmlDoc.loadXML(sAXLRequest);
xmlhttp.Open("POST", "http://" + ccmserver + "/CCMApi/AXL/V1/soapisapi.dll", false);
xmlhttp.setRequestHeader("Authorization", "Basic " + authstring);
xmlhttp.setRequestHeader("Content-type", "text/xml");
xmlhttp.Send(xmlDoc);
// Return the XML response
return xmlhttp.responseText;
... unfortunately i dont get anything back...
the base64enc works and gives the correct string back..
can someone plz help me??
thanks
200
