TSP 2.01 CCME 4.0 does not authenticate
Hello!
I can not make TAPI TSP 2.01 to work with CME 4.0(1) IOS Version is 12.4(4)XC2
this is needed to dial from outlook
in ephone I have added username line – see below
when I have installed TSP 201 (Version 2.0.105.70) it did ask me for IP, username, password etc…
BTW option Emulate an IP phone is grayed-out.
Than I press Start button to verify registration and I can see that it did not work out…
Connecting to host '10.0.4.101' [10.0.4.101]...
Host '10.0.4.101' [10.0.4.101] responded successfully.
32 bytes received in 16 msecs.
Found Router : 10.0.4.101
Error: Can not register user. Invalid IP-address, User name or Password
What is wrong? and Thank you in advance
ephone 2
keypad-normalize
device-security-mode none
ephone-template 10
keyphone
username "user1" password helloworld
mac-address xxxxxxxxx
type 7940
keep-conference endcall
button 1:2 2:7
Anonymous
N/A
Re: TSP 2.01 CCME 4.0 does not authenticate
Cisco IOS Telephony Service Version 2.0 implements only a small subset of TAPI functionality. It does support operation of multiple independent clients (for example, one client per phone line). The TSP support does not have full TAPI support for multiple user or multiple call handling, which is required for complex features such as automatic call distribution (ACD) and IP contact center (IPCC). Also, this TAPI version does not have direct media and voice-handling capabilities.
This URL should help you:
http://www.cisco.com/univercd/cc/td/doc/product/access/ip_ph/ip_ks/its20x/ipkey2.htm
IOS problem, username and password need to be in capitol letters.
http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K68099022
Did you get this sorted?
I've installed TSP 1.3 and connected to CME 4.0 OK.
I actually used the GUI interface to set the username and password (shame, I know) but the username entry under the CLI is the same format as what you entered. It appears to me that the only thing the TAPI needs is username, password and CME IP address and it should work
136
