Community Member
TTS 3.1.3 Unity
Is TTS editable with Unity 3.1.3, are there tools to improve the quality of the reader?
George
Re: TTS 3.1.3 Unity
No, there's currently nothing available to improve the TTS.
Gold
Re: TTS 3.1.3 Unity
Keep in mind that Unity has two TTS engines available, RealSpeak and TTS3000. RealSpeak costs more and sounds better. If you have TTS3000 you might want to by an upgrade with RealSpeak.
Markus is correct from a supported standpoint and if you have RealSpeak you only have the one 'female' voice. If you have TTS3000 it is possible to change the speakers voice however. I caution you that nothing but the default has been tested and none of these are supported. i.e. back things up before you start making adjustments.
Go to HKLM\Software\Active Voice\TTS\1.0\Initialization\Speakers
There you’ll see keys for each of the languages (ENU is US English which is the one I’m guessing you want to adjust). This change does require you restart Unity.
These are the available voices:
CHS:
Dawei
Shumei
DEU:
Anna
Stefan
ENG:
Carol
Peter
ENU:
Alex
Biff
Deep Douglas
Eager Eddie
Grandpa Amos
Julia
Melvin
Michael
Michelle
Peter
Sidney
Wanda
ESM:
Carlos
Ezequil
Isabel
Jorge
Josefa
Luis
Paco
Pedro
Ricardo
Rogelio
ESP:
Carmen
Julio
FRA:
Pierre
Véronique
ITA:
Barbara
Stefano
JPN:
Kenji
Naoko
KOR:
Jun-Ho
Shin-Ah
Shin-Ah 8kHz
NLD:
Alexander
Linda
RUS:
Boris
Svetlana
111
