Two ATA-186 connects problem
I connect two ATA-186 on different location, Hong Kong and China. We want to use Fax machine to connect. In the china, I use the version is v2.16 ata18x (build 030509a)(H.323 and SIP). In Hong kong, I use the version is V2.11(H.323 and SIP). Now, I set the ATA run on the fax-Relay. But I meet some problem. I fax 5 of pieces of papers, The error occur. On the Other hand, Both sides is connected to Line 2 to send the fax, no paper can send out and receive. Error also occurs.
I don't know what problems is ?
Please help me!!!!!
Re: Two ATA-186 connects problem
The ata 186 does not support fax relay.
http://www.cisco.com/en/US/products/hw/gatecont/ps514/products_qanda_item09186a00800946e1.shtml#Q33
Configure fax passthrough for the ata 186.
How can I config to the Fax pass-though mode ? Do You have any suggested about my configure. I have changed the default seeting in ATA-186
Audio Mode : 0x00000012
Tx Codec : 3
LBRCodec : 3
RxCodec : 3
ConnectMode : 0x00068400
The other setting is the Network. e.g. : Gateway, StaticRoute, StaticIP,...,etc.
I follow the default at other configuration except the above configuration.
Thx
116
