Two questions ?
Does 7961/41 work with CME ?
This matrix shows it doesnt
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/prod_installation_guide09186a008055677f.html
The Cisco pricing list (latest) does not indicate a license for 7961 or 7941.
SW-CCME-UL-7960 (dont see any for 7961)
SW-CCME-UL-7940 (dont see any for 7941)
Can the 7940/60 licenses be used for 7961/41 ?
Question no 2:
Does RPS 675 work with the same cable with a 3750 switch as well as a Cisco 2800 series router ? If yes what cable needs to be used ?
CAB-RPS-2218 or CAB-RPS-1614=
TIA
VIP Purple
Re: Two questions ?
Although I can't find a document that states this as a fact, the 2 links in the following post seem to point to the fact that the 7941 is supported in CME.
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=IP%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1dda5336
Brandon
Super Bronze
Re: Two questions ?
Hi Shanky - hope you're well.
Yep - the 675 works for the 3750s (did this a while back) and uses the 1614 cable. The 2821 data sheet says it works with the 675 so it will use the same cables...
I think the 2218/2208 cables are for the older RPS units.
No idea about the 7941/61s and CME, but I'd definately be interested to hear if you or anyone tries it - I've been hesitant to spec them yet...
Hope this helps
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Re: Two questions ?
Work has been killing me for past few weeks..craving for a vacation here soon.
Thanks for the info on the 675.
I confirmed with Cisco, that 7961/41 is currently only supported in callmanager. Though there is a roadmap to support it in near future in CME.
Community Member
Re: Two questions ?
Just an update, I've used 7961G with CME 4.0, with some tricks it works just great.
124
