Community Member
UCS C220 with raid v6 problem(not support any CUCM versions)
pease help me in the below problem
after installing UCS C220 with raid 6, i tried to make new v-machine for CUCM but it gives me the below message:
The hardware you are using is not supported for this product. installation will now halt.
1 ACCEPTED SOLUTION
Are you using the CUCM OVA?
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
java
java
Community Member
thank you brother solved
i used OVF template and after that alhamdulellah solved
251
