UDP port configuration on Cisco 7960 MGCP Load
I am using Cisco 7960 with MGCP load on it. I am getting one way media for inbound calls when my phone announced 21044 as the UDP source port for RTP stream. My query is how can I change the configuration on my phone to use any other port range other then 21044.
The show config on the phone shows :
start_media_port : 21024
end_media_port : 21044 (I want to change the end_media_port to 21043)
Application Load ID : POM-06-2-00
Boot Load ID : PC030301
DSP Load ID : PS03AT38
Re: UDP port configuration on Cisco 7960 MGCP Load
This info can be changed in the MGCDefault.cnf file and the MACAddress.cnf file.
You will find these files on the TFTP server that the phone used to download the configs.
Please make sure you make appropriate changes on the call agent too. Otherwise, there willbe a mismatch.
Thank You..
168
