Ugrade and ActiveFax
I will be performing a Unity ugrade from 2.4.0.120 to 2.4.6. I am concerned with the ActiveFax portion. I know I will have to uninstall Dialogic software but do I need to uninstall ActiveFax? If I do not have to uninstall Activefax do I still choose to install faxing when doing the upgrade? Are there any known issues with upgrading and ActiveFax? Thank you for any advice regarding this upgrade and how it affects ActiveFax.<br><br>
1 REPLY
Anonymous
N/A
Re: Ugrade and ActiveFax
For the upgrade path you describe, you do not have to uninstall Active Fax first before upgrading.
When you are ready to upgrade, choose to install Active Fax during the setup and it will upgrade your Active Fax software as needed (this assumes Active Fax and Unity are on the same box).
If it's a two-box scenario, upgrade the Active Fax server first, then run the upgrade on the Unity server, again choosing to install fax (it will ask you to point to the fax server).
86
