UM Design w/SRST and Centralized Call Processing
Location A:
Call manager
Unity
Local Gateways
own Exchange Org and Domain
Location B:
Uses Call manager from Location A
uses SRST for backup
uses Unity as Auto Attendant
In this scenario can I run a Unity server at Site B? What happens in SRST mode? Can Unity Express work here?
Gold
Re: UM Design w/SRST and Centralized Call Processing
Due to some serious limitations in the MAPI protocol we don't support Unity connect to Exchange over a WAN link. So in this situation you would need to have a Unity server at both sites. Microsoft is working on coding a fix for us so this could change down the line.
Even if you did have a Unity server at each site Unity can't work with SRST like the phones can. So during a failure Unity isn't going to be able to register with the SRST router.
What you can do is leverage Unity's Digital Networking and have Unity A be the auto attendant for both locations. Then if the WAN link is down you can route calls over the PSTN so that the user’s phone in Location B will at least ring.
Hope this helps...
Keith
In this scenario does it matter that the 2 exchange servers are different (1) 5.5 and (1) E2K and in different domains. They do require Unified Messaging at location B.
114
