Un-answered calls get charged.
Hi !
We have connected a 5300 to PSTN by a channel Bank using R2CAS signaling.
PSTN-Exchange=====Normal-Analog-lines=====Channel-Bank--------R2CAS(E1-PRI)-----5300.
The configuration is
controller E1 0
clock source line primary
ds0-group 0 timeslots 1-15,17-31 type r2-digital
cas-custom 0
voice-port 0:0
echo-cancel coverage 16
compand-type a-law
cptone DE
timeouts interdigit 30
timeouts ringing 60
timeouts wait-release 20
IOS is Version 12.1(3a)XI7
Router#sh vfc 1 version vc
Voice Feature Card in Slot 1:
VCware Version : 7.16
ROM Monitor Version: 1.3
DSPware Version : 3.4.27l
Technology : C549
Debug-Output
2003-01-14T06:41:37Z|source|2003011405422730711|7esgTSbBEdeCPaSNChH/kg==|4444|C01010|192.168.1.1|41114|abc2|192.168.10.15|31|s|1016|normal
call clearing|0|0|0|0|
The problem is even when a call is not answered ( just ringing) originating and terminating party gets the call charged in its billing system due to this normal call clearing message when call is disconnected. Any help how to change the message for un-answered call?? Thanks
1 ACCEPTED SOLUTION
Silver
Re: Un-answered calls get charged.
Our experience with R2 channel banks (you are using Valiant Communications units by any chance?) is that they send an answer signal on the R2 trunk after 30 seconds. This is because loopstart trunks normally don't provide any form of answer supervision, and R2 switches often need an answer signal to cut through the audio paths so they assume the call is normally picked up in this 30 second period.
Unless you remove the channel banks from the picture and use digital trunks direct to the exchange you are going to have to live with it ...
1 REPLY
Silver
104
