Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Bronze
Unable to start AVDSGlobalCatalog
Anyone get this error after a reboot in Unity 3.1(4)?
geoff
Re: Unable to start AVDSGlobalCatalog
Make sure the username and password that is used to log that service in is correct. If not, the service won't start. Is the AvDsAD service starting? Are you using the same log on information?
adam
Bronze
Yes. It seems that it clears the password when I reboot. I check the logon, and it is using the appropriate user, but the password is not correct. When I manually enter the password, it works fine.
geoff
149
