Community Member
Unassisted transfers to outside lines.
Out-of-the-box, does Unity allow for unassisted transfers (or access to) outside lines?<br><br>Some phone switches I have worked with in the past allowed you get to an outbound line by pressing 09<phone number>#. If this isn't disabled, the implications are obvious . . .<br><br>To this point, I can find nothing that indicates this feature is enabled in Unity at any point in any messaging. If it is enabled, what and where is the best way to disable?<br><br>
Anonymous
N/A
Re: Unassisted transfers to outside lines.
No. Some one would have to manually enter what ever dial string and phone number it takes to get to the outside into a Call Handler or Subscriber transfer field.
Steve Olivier
Software Engineer
Cisco Systems
Anonymous
N/A
If someone knew CM / Unity, would that be an easy hack?
Anonymous
N/A
Only if they had Admin console access.
Steve Olivier
Software Engineer
Cisco Systems
Anonymous
N/A
That's exactly the answer I was looking for.
Thanks for the assistance,
David.
126
