uneble to configure cisco ip phone 7960 series
Please I am unable to configure cisco ip phone 7960 series, I need to desactivate DHCP, but I can't
I don't see the option to unlock keyboard
How can I do ?
Iwould also like to know if cisco ip phone 7960 series can work with asterisk ?
Re: uneble to configure cisco ip phone 7960 series
Press **# once you're in the Settings > Network Configuration menu to unlock. Yes, the 7960 will work with Asterisk.
Hope this helps.
Brandon
you running a Skinny firmware on the phone?
if so, flash it to the SIP firmware.
plenty of forums that tell you exactly how to do that
Please remember to rate useful posts, by clicking on the stars below.
I d'ont really understand what is skinny firmware. But I am unnable to change network parameters of the phone
When I disabled DHCP and save , it don't accept
please helps
Bronze
Hi friend, first disable DHCP (DHCP Enabled=NO) then change the IP address, mask, default gateway, ip tftp server and then press save.
The phone will reset to load your new configuration.
All the best
David.
203
