I am looking into using number expansion on a 3600 voice gateway to append a # to the digits being sent to a pots peer. We have a 2 stage dialing scenario with variable length international calls.
Without the following entries, the gateway sends the international number to the pots interface and the inter-digit timer must expire before the digits are sent.
I understand that the expansion is global. Other than that, are there any other reasons to avoid this method?
Here's the Num-exp entries:
num-exp 011........ 011........#
num-exp 011......... 011.........#
num-exp 011.......... 011..........#
num-exp 011........... 011...........#
num-exp 011............ 011............#
num-exp 011............. 011.............#
num-exp 011.............. 011..............#
num-exp 011............... 011...............#
num-exp 011................ 011................#
num-exp 011................. 011.................#
num-exp 011.................. 011..................#
num-exp 011................... 011...................#
num-exp 011.................... 011....................#
num-exp 011..................... 011.....................#
