Unity 2.46 and MCS 7825
Hi all,<br><br>I bought a MCS 7825 and UNITY 2.46 8 ports from my CISCO reseller.<br><br>I'm facing a problem: there is no parallel port on the 7825 where I can plug the system key in.<br>I had to install the DEMO version which was not what I wanted to do...<br><br>7835 & UNITY 2.46 is fine, 7825 an UNITY 3 also, but it seems that my conf. is not a supported configuration ?<br><br>Is it possible to have my conf working, thanks to the USB driver ?<br>Any help would be very appreciated.<br><br>Thanks<br>Manuel.<br><br><br>
1 REPLY
Gold
Re: Unity 2.46 and MCS 7825
The 7825 was never supported for Unity 2.4.6. You are correct on the 2 supported configurations. You will need to either move to 3.0 and get the USB dongle or get a different server from the Unity HCL. The USB dongle will not work with 2.4.6.
Keith
Keith Chambers
Unity Technical Lead
Unified Voice Team, San Jose
Cisco Systems
kechambe@cisco.com
87
