Unity 3.1(5) service shutdown problem
jchorlton
Just upgraded to 3.1(5) from 3.1(3). All went well apart from .....
When shutting down the Server it can sometimes take 10-15 minutes to power off. After the Windows shutting down dialogue, the Server pauses with the Hard Disk LED permanently lit.
With 3.1(3) it shutdown very quickly.
After some investigation (loads of restarts), we have determined that shutting down the Unity Services (using the Unity Tray Icon) followed by shutting the AVDIRChangeWriter service allows the server to shutdown normally.
Has anyone seen this before?
Any bright ideas?
John
mattski1
John,
I've just upgraded a 3.1(3) to 3.1(5) and am experiencing the identical problem. Did you ever come across a fix? Jeff Lindborg, any ideas?
Many thanks in advance,
Matt
Even thought it is not a required patch, upgrading to SQL (MSDE 2000) SP2 seemed to do the trick.
Hope it works for you.
John
Hmmmm... I'd already applied SQL 2000 SP2 before Unity was installed. I wonder if the Unity installation process is overwriting a SQL file that needs to be updated again via the service pack.
Thanks for the clue.
Matt
Just a follow-up to this thread.
After reapplying service packs, etc. we were not able to resolve the "hang" at shutdown problem.
Until...
I finally noticed that when shutting down SQL 2000 the AvGaenSvr service was not being stopped. Sure enough, when stopped manually, the box shut down just fine.
After searching through these archives for that particular service, I came across a note from Jeff Lindborg mentioning that the 3.1(5) install/upgrade might be re-enabling the AvGaenSvr service when it should not have been and that the service was responsible for several looping bugs. Reading that the service was not required, we stopped and disabled the service and all automated shutdown problems appear to have been resolved.
