Community Member
unity 3.1(5) using exchange on a seperate box....
A unity 3.1(5) server is built using a message store that is on seperate exchange box.... and the message store that Unity is using will have to be moved to a new box later down the road. The new box that exchange is moved to will have the same site and organization name. Will this cause problems with unity? Also, the plan is to migrate to UM from VM we know the procedures to do this but will the exchange move to a new box effect the UM to VM migration? Thanks...
1 REPLY
Gold
Re: unity 3.1(5) using exchange on a seperate box....
Assuming you are using Exchange 2000 and the new server Exchange server will be **IN** the same Org you can follow these steps:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_unity/unity31/rel_note/cu315rn.htm#xtocid57
If the Exchange servers are in different Orgs, regardless of how similar the names are, you are looking at a reinstall. DiRT can help with the backup, restore and migration.
Keith
100
