Unity 3.X and ADC
We have got PDC NT4.0 and Exchange 5.5 Unity 3.1X. If we upgrade the NT40 PDC to win2k-AD and install ADC for Exchange would that upgrade break Unity. Is there anything we need to do after the upgrade for Unity. No mailbox movement or anything to the hardware is taking place. There is no EX2k upgrade...Later on if there is EX2k upgrade what we need to do on the Unity side...<br><br>Sean Poure<br>NEC-Voice Engineering<br>Sr. Aplication Engineer<br>714 4846275<br>
Sean Poure
1 REPLY
Anonymous
N/A
Re: Unity 3.X and ADC
As long as the ADC connection agreement is a one way going FROM the Unity Exchange 55 system TO AD you are ok. If you setup a two way connection agreement you'll cause all kinds of grief and wax your Unity install completely.
Jeff Lindborg
Unity Technical Lead/Answer Monkey
Cisco Systems
lindborg@cisco.com
http://www.AnswerMonkey.net (new page for Unity support tools and scripts)
115
