Unity 4.0(3) - Changing IIS port number doesn't work with Unity SM pages
We are looking at changing the port number used by IIS for the default web site on Unity.
This is a basic security fix to stop the box responding to scans on port 80 and something that works well on CallManager.
If you do this on Unity all appears well until you try and access the SM pages.
For example if you set the port number used by IIS to say port 399, then browses to http://unity-server:399/Web/SA work fine. However when you go to http://unity-server:399/Web/SM you get the 'Error: XML fetch failed -- possibly a problem with AvXml.dll or its permisions' message.
Before expending any effort re-inventing the round object.... Anyone else come across this and or a work around?
We're running Unity 4.0(3)
1 REPLY
Re: Unity 4.0(3) - Changing IIS port number doesn't work with Un
Looks like a straight up bug. The admin folks looked at it this morning and opened a DDTS record for this issue: CSCec44066
87
