Unity 4.0 auto-response to calls
dmunoz2006
Hello, i have a callManager and a Unity Machine, what i need is to make Unity to auto-responde a call to one number. Does anyone knows what documentation can help me to do this?
Brandon Buffin
David,
I'm not sure how you want to respond to the call, but a call handler in Unity should do the job. Take a look at the following link. There is a section on call handlers and their uses.
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_administration_guide_book09186a008043ea39.html
Hope this helps. If so, please rate the post.
Brandon
Brandon Buffin
David,
Brandon
Hin Lee
In Unity SaWeb, there is an option on the left for Call Routing. If you are configuring a cti port with that specific DN to forward to Unity, then create/configure an rule.
Tommer Catlin
HinHo is correct. You want to setup a Call Route Rule based upon either the circuit it came on in, (PRI, analog, etc) or the Dialed Number (800 number, DID, etc). From their you can direct it to play a Call Handler with your greeting. (auto response).
1. Define your call route
2. Define a Call Handler
3. Add you Call Route (based upon schedule, Dialed number or circuit, etc)
4. test.
hope this helps.
