Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Unity 4.0 - External voice messages are silent
This is a new installation. I verified that only one nic is enabled on the Unity server. The complete message is silent no matter the length of the message. If you chose option 3 to listen to your message before sending, its silent. If I try from an internal phone everything is fine.
Re: Unity 4.0 - External voice messages are silent
There's a couple other ways you can get this problem other than dual NICs - here's a couple tec tips that may be helpful:
http://www.cisco.com/warp/customer/788/AVVID/fix_1way_voice.html
http://www.cisco.com/warp/customer/788/AVVID/1way_audio.html
Thanks for the info. It turned out to be an IOS bug with ver 12.2(13)T1. I went to T3 and the issue was resolved. TAC said the sampling rate in T1 was not 20ms even though it reported it was.
91
