02-06-2003 03:06 PM - edited 03-12-2019 10:35 PM
After upgrading Unity 3.1(3.0) to Unity 4.0 everything was fine,
But there where several things which changed an are missing :
-) All Services are now running under Domain Users (which have been defined via Permission Wizard), before there where only two which ran under Domain Users
-) AA Web does not exist any more (in IIS there is an redirection to /ciscopca),
in IIS this web does NOT EXIST ???? Whats the problem, we removed the redirection of AA firstly, but i think thats not a clear implementation.
ANY SUGESTIONS AND EXPLANATIONSTO THESE PHENOMENONS ????
Helmut Schranz
02-06-2003 03:25 PM
1. All your AV services should not be associated with domain accounts unless you forced that to happen. By default when you run the permissions wizard it needs two domain accounts: one for messaging facing services (AvCsGateway, AvCsMgr, AvGaenSvr, AvMsgStoreMonitor, AvUMRSyncSvr) and one for directory facing accounts (AvDSAD, AvDSGlobalCatalog or similiar for 55 or Domino). The other services (AvDirChangeWriter, AvLic, AvMMProxySvr, AvRepDirSvrSvc, AvSQLChangeWriter, AvTTSSvr) all default to being "LocalSystem" unless you forced it to a directory account in the permissions wizard interface. There's no reason for these services to be associated with a domain account.
We had to introduce the 2nd account (i.e. seperate messaging and directory rights into two domain accounts) because of all the issues with explicit denies on the mailstores being introduced across various groups (i.e. domain admins among others) - it was nearly impossible to cram it all into one account and make it fly - we were getting _way_ too many calls about permissions issues as a result so we seperated the accounts with makes this a lot easier.
2. The AA is now the "Personal Communications Assistant" - the updated interface has a lot more to offer and is also where folks using VMI go. Here's the link in the admin guide talking about how to set it up and use it:
02-06-2003 05:16 PM
Hi Lindborg & steve
Many thanks for your help, but now we ran into several problems :
1.) we have 2 Default Administrators, I want to add a third one :
I get : "The new class of service {Default Administrator}, has insuficient licenses. Reverting to priviously saved class of service"
DOES this mean that I only can have 2 Default Admins ????
2.) we checked Services again here is the list :
Directory Service Account handels following services
AvDirChange Writer, AvDSAD, AvDSGlobalCatalog, AvLic, AvMMProxySvr, AvRepDirSvrSvc, AvSqlChangeWriter, AvTtsSvr
Message Store Service Account handels following services
AvCsGateway, AvCsMgr, AvGaenSvr, AvMsgStoreMonitorSvr, AvUMRSyncSvr, CsBridgeConnetcot
SHOULD we change the rights as you suggested, and do you have an short fact sheet why, please ?
3.) IIS Screenshot :(see attachment)
within VisualMessagingInterface there is no file
ciscopca does not exist at all
so it seems to be that an installation of this web did not happened
WHAT CAN WE DO here now
02-06-2003 05:58 PM
Hi Lindborg & steve
02-06-2003 07:09 PM
No, there's no limit on the number of admins you can have on the box. Check the class of service you're trying to use here (the Default Administrator COS) and look on the "licensed features" page and I'm betting you have an option checked for which you are out of licenses. Either that or you didn't apply your license file properly on 4.0(1) and your out of licenses subscribers - you can check this on the "Licnesing" page in the SA - there's two pages, one for counts of users (total users you can have) and one for licnesed features (how many seats of VMI, TTS etc... you can have). One of these is going to be maxed out I'm guessing which is why it's not letting you change COS assignments.
If the system is working there's no reason to change the rights assingments - there's nothing wrong with a few of those services that normally run under "LocalSystem" being assigned a domain account instead. I'd probably just leave it alone.
Not sure what you want in the way of a "fact sheet" here... The help file for the Permissions Wizard gives a very detailed list of all the rights it grants to each account - that's probably the best I can offer. If you don't have it handy, you can get it here:
http://www.ciscounitytools.com/HelpFiles/PWHelpPermissionsSet.htm
The IIS question was answered on another thread - there isn't a folder/file that is going to show the PCA web root or the like, the new PCA is all done in Java with STRUTS and you get there via a redirection service added into IIS by installation - I suspect you disabled this redirection capability and this is why you can't get to the page.
02-06-2003 03:31 PM
What you are seeing is totally expected, but not always easy to find documentation on. The 4.0(1) release notes should cover both of these changes and more. For the issue about the accounts for the services, that's done by a wizard that's run during the 4.0(1) setup/upgrade...
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/prod_release_note09186a0080117edc.html#2135518
For issue about the web changes, that's changes that happend with the introduction of the Cisco Unity Assistant....
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/prod_release_note09186a0080117edc.html#2011886
And here's a link to the root of the release notes...
