Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
Unity 7 VM .wav volume too low
I just converted to Unity 7 UC and some users are complaining that the volume on the .wav files is too low even when they have the volume turned up all the way. I saw other posts from unity 3, etc.. that wanted you to adjuct the gain levels on the voiceports. Is that still valid and if so, do I adjust them on the remote side that is experancing the low volume issue.
Thank you for your help.
Tom
Re: Unity 7 VM .wav volume too low
Thomas,
Please check the following guide for troubleshooting volume issues with Unity connection:
"Problem with the Volume of Recordings"
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/troubleshooting/guide/7xcuctsg060.html#wp1052958
It will explain how to adjust volume.
HTH,
pablogon
Thanks for your reply. I saw that artical also. I was looking for confermation. I will follow the process described.
417
