Unity and Avaya Intuity Integration
wgellenberg
I need to know if the Intuity voicemail can support two (2) different vendors PBX at the same time? Say a Definity G3 and CiscoCallManager/Unity VN integration?
I want to keep the Intuity VM connected to my G3 and maintain users on that system, but I also want to install a Cisco CallManager and Unity at another location and integrate both voicemails to share messages.
I have been told by Avaya that the Intuity only supports one PBX at a time and they must be ordered/configured for the PBX that it connects to.
Has anyone had any experience with Intuity and Unity integration?
mmitchell
The bust shot you have is to check with Avaya and see if the Intuity will support AMIS. if so then you can connect the Unity and Intuity via the AMIS protocol
Marcus
