Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Unity and SAN
I am going to be doing a Unity migration for a customer 2.46 to the latest. Their current server does not do any RAID and the customer would like to interface the server w/ a Xiotech Magnitude via Fiber Channel. They have all their servers configed this way and would like Unity to become part of the standard.
I told them sounds great, but let me check to make sure. What I did tell them is that TAC would probably only support the Unity application and software related problems. Anything to do with the SAN is out of the question.
Are there any limitations for the customer doing this?
Thanks.
Gold
Re: Unity and SAN
Unity connecting to a SAN has not been tested and as a result, is not supported by Cisco. I am not aware of any plans or roadmaps to qualify this type of configuration.
Keith
Re: Unity and SAN
If Unity is pointed to a off box message store, and the exchange on that off box message store is using a SAN, why would Unity even care? IT sounds more like a MS/Sxchnage issue at that point.....
Gold
Re: Unity and SAN
Your right and that configuration is fine. You just can't connect Unity directly to the SAN.
Keith
80
