Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Unity as a multi-tenant platform
Can Unity 4.0x be used as a secure service provider multi-tenant messaging platform? If so, can you direct me to a design document that details the best practices or suggested deployment model(s).
Thanks in advance.
1 REPLY
Re: Unity as a multi-tenant platform
Unity doesn't have explicit support for tenant services in 4.x - you can do some things to make it "close" to simple tenant services - I detail some of this information in the "Audiotext applications in Unity" doc on the Documents page on www.CiscoUnityTools.com - there's a section in there specifically for the limitations of what you can/can't do here that should get you from A to B on this one.
87
