Unity Backup using Veritas
Hello Guys,
I am looking for the step by step procedure to how backup Cisco Unity (4.1) using Veritas Backup Software. Could you please hlep?
BT
1 REPLY
Re: Unity Backup using Veritas
BT,
The following document contains instructions for using Veritas with an ICS7750, but it should largely apply to a server environment as well.
http://www.cisco.com/en/US/products/hw/voiceapp/ps967/products_tech_note09186a008011a978.shtml#topic7
Cisco's official stance on 3rd party backup software with Unity is that it's OK, but if you have a problem and TAC determines that the backup software is at fault, you will be asked to disable or remove it. See the following link.
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/prod_system_requirements_hardware09186a008061eab9.html#wp468097
Hope this helps. If so, please rate the post.
Brandon
119
