Unity - Brooktrout and Dialogic
Has anyone been able to install a LightningFax Brooktrout PCI card in the same server as a Dialogic analog card? I realize that LightningFax doc says it can't be done (hardware address conflict). I've tried using Dell's resource manager to configure the cards manually - no luck.
Unity version is 3.0(3) - Win2k
Re: Unity - Brooktrout and Dialogic
Are you trying to install the Brooktrout card into the Unity server? Are you trying to install Lightning Fax on the same PC as Unity?
With either one of these configurations, you would not be supported by TAC -- it is also better to have a fax server on a seperate machine because of the performance hit associated with rasterization.
Yes, not only do the hardware addresses conflict, but the LF software disables the Unity Web admin!
134
