Unity Connection 7.0.1 in VMware
Hi all,
I would like to build a lab environment in order to produce some installation documentation for Unify Connection.
I am running an original DVD 7.0.1.11000-2 on a VMware workstation 6.0.0.
I have read: http://www.cisco.com/en/US/customer/prod/collateral/voicesw/ps6789/ps5745/ps2237/product_data_sheet0900aecd806bfc37.html
Could anyone confirm that there is no way to get it up and running under such setup?
I did several attempts with different configuration (VMware version, hardware setup, etc...) and didn't succeed.
Everything runs fine but after the boot of the OS Unity encounters a critical error during the RPM installation and stops:
05/27/2009 09:36:17 IPM|Internal Error, File:ipm.c:1952, Function: ipmReadNormalizedInputLine(), Error seen while installing "rpm -i --percent /common/rpm-archive/7.0.1.11000-2/RPMS/cm-dbms-1.0.0.0-1.i386.rpm 2>&1": unpacking of archive failed on file /usr/local/cm/install/ids/csdk-install.tar.gz;4a1d6bfe: cpio: MD5 sum mismatch|<LVL::Critical>
05/27/2009 09:36:19 IPM| end-of-session "Installing Packages": 15.206 secs.|<LVL::Info>
05/27/2009 09:36:19 IPM|Close progress meter "Application Pre Install"|<LVL::Info>
05/27/2009 09:36:19 post_install.sh|CCMInstall --install-pre returned 1|<LVL::Info>
05/27/2009 09:36:19 post_install.sh|check_for_critical_error, found /common/log/install/critical.log, exiting|<LVL::Error>
05/27/2009 09:36:19 display_screen|Arguments: "Critical Error" "The installation has encountered a unrecoverable internal error. For further assistance report the following information to your support provider.
The system will now halt.
Thanks a lot!
Salim
1 REPLY
Bronze
Re: Unity Connection 7.0.1 in VMware
I have the BETA 7.0 running in VMWare Server 2.0. I had issues with installing 7.x products until I bumped the harddrive space beyond 80GB.
MD5 sum mismatch
This error looks to be your installation media is corrupted or modified, because it failed the MD5 hash check. I would get new media.
721
