Community Member
Unity Connection - Problem Attempt Transfer After Greetings
Hope someone can help on this. :)
I am using Cisco Unity Connection version: 1.1(1) SR1.
And in the User - Greetings - Standard Greeting Section, I am trying to attempt transfer to another user with voicemail box for extension, 1234.
However, there is only a selected list of extension under the scroll selection. I have clicked on the Find button and selected the extension 1234 and click on close. However the extension still does not appear under the scroll list.
Anyone has encountered this and found any solution for this?
Thanks a lot. :)
Eugene
1 ACCEPTED SOLUTION
Community Member
Re: Unity Connection - Problem Attempt Transfer After Greetings
I just found a solution
Bug CSCse40931
Unity Connection Find User page can't add when only one user is found
If your search results only bring up one option it will not select the user. Try using a search with more than 1 result. I did that and was able to select the user then. it looks like the bug is fixed in version 1.2(1)
here is a link
http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCse40931
Anonymous
N/A
Is the other user in the same cluster?
Community Member
I am having the same issue as well but under Call Handlers when assigning a number to transfer to an extension or greeting.
Running the same version of connections and all users are in the same cluster/system
Community Member
Bug CSCse40931
here is a link
Community Member
Hi kwaldecker@netdsi.com,
You hit jackpot. When I search for '123' and it gave a 10 search results, I was able to select the extension to transfer to.
Thanks all for your replies. Case closed.
Eugene
Community Member
Eugene,
Try searching for the alias for user with extension 1234.
Steve
280
