unity connection
any one know where I can get a copy of unity connection platform disc? or is there a registery hack?
Hall of Fame Super Silver
Re: unity connection
Here is the link:
http://www.cisco.com/cgi-bin/Software/Tablebuild/tablebuild.pl/11unitycnx
the heck is to use /NOPCD switch, so simply go to run
enter setup.exe /NOPCD, you will however need windows 2003 servr with SP1.
HTH, please rate all posts!
Chris
Hi ,
SO do I need to install windows 2003 server (SP1) first, then insert unity connection dvd ,
start _ run_ setup.exe /NOPCD ?
Correct!
Chris
120
