Unity does not answer external call
I have installed a version 2.4.6.135 of Unity with a release 3.1.1 of the Call Manager.
Fot the internal calls, no problem, when a call is routed to Unity, everything works. But for the external calls, Unity see the call (on the call viewer). but Unity doesn't take (answer) the call... Any clue to resolve this ???
Bronze
Re: Unity does not answer external call
The Clue is the Voip dial-peer on the Router.
Select the codec "g711ulaw".
Good Luck
mehmet
thanks a lot ... indeed, it works
Frederic
105
